Topic: Script School - Page: 9.7
Because sampler is not a real deck (dynamic); as locodog said, it is used as a slot
Internal technical limitations:
Decks are using positive numbers to identify, null being Master or Default depending on usage
To identify other decks the solution was to use negative values. This apply to sampler and mic and aux
Instead of doing things like "deck -n" the decision was taken to access them the same as a slot, such as "Release"
(now 6 slots seems to exist there may be differences)
Thanks Nicotux and Locodog.
But it is a shame because many more things could be done, if the sampler had more slot and to be able to handle parameters at the same time of different effects.
Is it possible to specify the time for one beat as the interval instead of 1000ms?
Nicotux wrote :
a simple loop to wait 1 sec (1000ms) I name it 'wait1' in this example:
repeat_start 'wait1' 1000ms 1 & ...
this define a simple loop 'wait1' looping 1 time after 1000ms
@twaga yes but not with dead on precision, even if you state 1000ms, it might happen in 995ms or 1005ms. It's a bit fuzzy.
off the top of my head, to get ms/b into a RS script
get_bpm & param_1_x & param_multiply 60000 & param_cast 'ms' & repeat_start 'Name' & ACTION STUFF
but since you can't include a counting param you have to manually stop the RS script
something like this is an example, however this can cause problems with an implicit being set
that is a different story
effect_active 'ducking echo' on & param_multiply "get_bpm & param_1_x" 60000 & param_cast 'ms' & repeat_start 'name' & play ? slip on & play_pause & cycle 'mCounter' 40 & var 'mCounter' 0 ? repeat_stop 'name' & effect_active 'ducking echo' off : nothing : play_pause & slip off & cycle 'mCounter' 40 & var 'mCounter' 0 ? repeat_stop 'name' & effect_active 'ducking echo' off : nothing
Good morning all,
I discover the world of djing and I have no concept in mapping.
I have a numark nv2 table and would like to modify it slightly to make it easier for me.
When I press the "sampler" button I would like to open my sample bank and assign 1 pad for each sample, but unfortunately the bank does not want to open. Once it is opened with the vdj the pads are well assigned but no function from the controller.
Second I have 2 cue menus and I would like the second menu to be a "piano" mode of my cues.
Thank you in advance to all
Sorry can't help with your request but I notice a bug in the mapping of the NV II
as this is in related KEY i found it important to report:
PAD_MODE_SAMPLER mapped to
pad_pages 4 ? holding ? pad_pages 19 : pad_pages 8 : pad_pages 8 : pad_pages 4
should be something else like
pad_pages 4 ? holding ? pad_pages 19 : pad_pages 8 : pad_pages 4
some tips for mapping pads and samples:
to open browser sampler tab:
sideview "sampler"
or
page sampler
to select sampler pad :
pad_page sampler
to open the bank of samples :
sampler_bank
moving a sample from browser to the sampler tab grid/list automatically affect it to the sampler padpage pad
(in grid mode the position have to be guess) and names do not always match in browser tab and pads
sideview_triggerpad
toggles (or can set on and off) between grid view and list view
Question:
With 1 button: press and switch on sampler effect and press again then switch off sampler effect.
ej: effect_active sampler 'echo' ? effect_active sampler 'echo' on & effect_active sampler 'echo' off
It does not work.
replies wrong way round, [*edit* your script hasn't an false reply to the query]
is SOMETHING on ? [yes it is] turn it off : [no it isn't] turn it on
the : is important.
your script as is, is asking
is SOMETHING ON ? [yes] turn it on AND turn it off [that's it, you don't give a no reply
So?
effect_active sampler 'echo' on ? effect_active sampler 'echo' off : effect_active sampler 'echo' on
the : is important.
in the absolute yes
but the verb effect_active is a toggle action
is enough
Thanks Nicotux.
Nicotux wrote :
in the absolute yes
is enough
Thanks Locodog
the : is important.
Hey ! I am triing step sequencer pad...BUt I already have a problem. For the get_beat_num division no problem but how to divide beat in 2 or 4 ? or maybe in triplet...? thanks in advance :-)
get_beat_bar 1
Hi, does anyone know how to do the Richie Hawtin effect with the Virtual dj effects?
In Traktor it uses the tape delay capturing the sound and playing with the tonality.
But in Virtual dj we do not have the tape delay effect or the parameters that it has in the virtual dj delay.
Any suggestion?
hi at all! i have this question: i have written script: action_deck 1 ? deck 1 sampler_bank ‘recordings bank’ : action_deck 2 ? deck 2 sampler_bank ‘instruments’ : nothing
(for have in pad_page ‘sampler’ about deck 1 and 2 two different sampler bank) but don’t work :( could do this?
there is only one sampler and have dynamic deck assignment so that your script can't work
action_deck 1 ? sampler_bank "Recording Banks" : action_deck 2 ? sampler_bank "Instruments" : nothing
work fine but may not do what you expect
it needs to be in both decks exactly the same as
button on deck 1: sampler_bank "Recording Banks"
button on deck 2: sampler_bank "Instruments"
maybe you better want
working depending on selected deck:
deck default get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" : nothing
or
working depending on the deck with higher level:
deck active get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" : nothing
or better a switchable repeat script doing it for you ?
repeat_start swsmp ? repeat_stop swsmp : repeat_start swsmp 48ms -1 & deck active get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" :
Quick question:
Why does
deck left play ? color 'green' : color 'green' & blink
NOT cause a launchpad LED to blink, when the left deck is not playing? (above is the mapping for the LED, not the pad action)
The pad is green, just does not blink.
18%
