Streaming completed mixes for a radio show and the software just stops playing like 10 minutes before the end of the mix. It will restart another track or at the beginning of the original but will not play past the point it shut down. Windoes just did another #$% update, never was a problem before that.
geposted Fri 25 May 18 @ 2:02 am
A windows update rollback may be needed
Also, do your VDJ license let you use the software for radio show streaming?
geposted Fri 25 May 18 @ 7:11 am
