so i just bought a AMERICAN AUDIO VMS02 and i'm unable to figure out how to pre-listen to my headphones while the other deck is palying.
this is my current setup:
https://imgur.com/a/XFg16sF
geposted Sun 27 May 18 @ 12:17 am
Set the headphones to 3&4,
after that check your cueMix on the front panel.
geposted Sun 27 May 18 @ 12:48 am
sorry that pic was wrong, they were set to 3&4 already.
and it's set to cue mix.
geposted Sun 27 May 18 @ 1:23 am
if i change it to cue, nothing comes out.
geposted Sun 27 May 18 @ 1:26 am
Any reason you are using a build over a year old?...
geposted Sun 27 May 18 @ 1:48 am
Are you using the default audio config or something you just guessed, drom what I've read the set up should be
deck 1 1&2
deck 2 3&4
deck 1 1&2
deck 2 3&4
geposted Sun 27 May 18 @ 2:01 am
Read the setup guide...
https://www.virtualdj.com/manuals/hardware/americanaudio/vms2/index.html
geposted Sun 27 May 18 @ 7:09 am
