Topic: pioneer ddj sx2 mic problem.
hi.
i am using pioneer ddj sx2 with vd8 pro and windows 10.
i have problem with the mic 2 is not working.
mic 1 works fine.
do i have to check in vdj8 settings or the problem comes from the controller?
thanks!!
geposted Tue 29 May 18 @ 6:27 am
The Mic inputs are hardware inputs and not part of the USB Audio Interface, so VirtualDJ doesnt control these inputs neither can be included in Audio setup.
If a Microphone is connected at the MIC2 input at the rear (CH4) and the front CH4 switcher is at MIC2 position (front) then you should hear it in the Master Output of the SX2.
geposted Tue 29 May 18 @ 10:05 am
hi.
thanks for your reply.
i use mic 2 as i use the mic 1.
i do all it needs to do.connect the mic jack cable at the back of controller then at the frond... switch the pc-mic2-cd to mic2 on channel 4 and still the mic 2 is not working.
maby the channel 4 fader have problem as i use 1 and 2 to work.
i think i will connect the channel 4 at pc and try to use it to see if is working.
thanks a lot!!!
geposted Tue 29 May 18 @ 10:52 am
