Topic: Can't hear SAMPLES
2mvp8102PRO SubscriberMember since 2014
I can't hear my samples over my music, unless I play them off a deck,,,,When I play them off my pads..I can't hear them over the music.
geposted Wed 30 May 18 @ 4:13 am
Open the sample, and raise the level to where you want, and save.
geposted Wed 30 May 18 @ 4:17 am
Thank You....didn't know about the SAVE part....much much better!!!
geposted Wed 30 May 18 @ 4:29 pm
blckjckPRO InfinityMember since 2008
Since you mention pads, I am thinking you may be using a controller. Does your controller have a volume control for the sample output? Say a fade or pot?
geposted Thu 31 May 18 @ 5:09 am
