I've got this creating a folder "search results" and a sub folder "artist-title" in playlists, then it reads the playlists, any it finds containing browsed filepath it copys to the folder.
There's one snag to fix which should be done this evening, probably have something for Kradcliffe to beta today.
geposted Thu 19 Jul 18 @ 9:49 am
Cheers buddy!
geposted Thu 19 Jul 18 @ 9:52 am
@PachN
That's not convenient. I can also install Bash and do an "grep" on the files, but that's not the same.
Like I said before in Traktor one can right-click on a track and choose "Search in Playlists".
No need to go outside the program and use other tools.
geposted Fri 20 Jul 18 @ 3:23 am
Any progress :-)
geposted Fri 10 Aug 18 @ 2:34 pm
It works well. drop Locodog a PM.
geposted Fri 10 Aug 18 @ 4:22 pm
PachN wrote :
Wouldn't make any sense to develope such a tool.
As a workaround just use Notepad++ and open all playlists with it.
Now do a search over all open documents and Notepad++ will show you a summary which document is containing the search string.
groovindj wrote :
I reckon PachN is probably the guy to talk to about this. He already has some playlist utilities, so could presumably add this function to one of them (if indeed it's not there already).
In Windows 10, just browse to your playlists directory in Windows Explorer, and then search the directory for an artist name. It will return all the playlist with the name, even if the name is not in the title of the playlist.
geposted Fri 16 Aug 19 @ 4:40 pm
Locodog:s plugin works for me.
Windows search also works.
Been asking for this to be integrated in VDJ since dinosaurs roamed the earth.. In all fairness Atomix have added loads of features I've asked for but this, ableton style warping for the beat grids and live BPM are still to go :)
geposted Fri 16 Aug 19 @ 7:19 pm
