I downloaded milk drop and can't get it to work. The read me file says to extract the zip file into the plug ins. I've tried copying in several of the files into the plug in folder, but can't get anything to work. Any ideas what I might be doing wrong or not doing?
geposted Thu 31 May 18 @ 10:41 pm
It has to be a 32 bit plugin, 64 bit plugins will not launch. You have to close and restart VDJ. Is it a visualizer of some sort?
geposted Fri 01 Jun 18 @ 7:05 am
This may help you
(My screen capture software can't quite capture it so there is a bit of blinking - but it should give you the idea though)
geposted Fri 01 Jun 18 @ 7:25 am
Just installed it and it works fine here.
geposted Fri 01 Jun 18 @ 7:48 am
