Topic: VDJ 2018 'Video_Fx' Command Changed
Before VDJ 2018, the command (mapped to a button or key) 'deck master video_fx "plugin"' activates/deactivates the plugin and shows the plugin in the video effect slot of the master deck (and its corresponding controls).
In VDJ 2018, the same command activates/deactivates the plugin BUT does not update the video effect slot with the plugin.
The command 'video_fx_select "plugin" & video_fx "plugin"' does the job but the 'video_fx_select' command deactivates the previous plugin in the slot resulting in only one video effect running at a time. The only to way to have multiple video effects running is by selecting the plugin thru the video effect pulldown menu.
Is there any new command or scheme that I am missing to make this work the same way with mapped keys and buttons? Thanks for a reply from the Dev Staff.
geposted Thu 07 Jun 18 @ 11:07 pm
The action deck master video_fx_select "plugin" works fine here.. it updates the V.EFFECTS drop-down in the Skin. Which one have you tried ?
To select a different Plugin, without de-activating the previous one, you can try ..
deck master effect_select_multi "video" "PluginName" & deck master video_fx
Tip: you can use all the effect_ actions for the "Video Slot", by adding "video" as above (or "transition", "audioonlyvisualisation", "colorfx") after the action and before the other parameters.
geposted Thu 07 Jun 18 @ 11:20 pm
Bingo!!!
The above command did it! Thanks so much @djdad for that prompt spot-on response. My workflow is back on track with VDJ 2018.
geposted Fri 08 Jun 18 @ 12:09 am
muchas gracias ! lo estaré instalando enseguida
geposted Fri 08 Jun 18 @ 1:59 am
