Topic: shader.com
VDJ RonPRO InfinityMember since 2010
So 4 hours on Saturday went well with vdj 2018, and 5 hours on Sunday but then things went wrong. At the end I could not drag the browser bar and select a song using the vdj skin. When I tried I got the shader.com box appearing????? This happen around 6 times. I was able to select and load songs using my controller. I repeat that for 5 hour all was well..I have no idea what happened.
geposted Mon 02 Jul 18 @ 1:13 am
Yes!
I couldn't figure out the cause I thought it was a vst
, an invisble box over the browser area, the pointer turns into a finger and if you work the mouse slowly you can find the edge and get resize the box then it appears as a large black square, only happened the once and I had no idea how to recreate,
I should have tried reloading the skin.
geposted Mon 02 Jul 18 @ 1:18 am
I had about 25 min to get to the end..I don't normally use the knob on my xdj r1 to navigate and load songs but am very glad it worked.
The little arrows above and below the navigation bar did work so I could use them to find a song but could not select and load it using drag and drop.
I did not use the internet all night.
Why would things go wrong after 5 hours?
geposted Mon 02 Jul 18 @ 1:26 am
Yes Loco..it was like something was over the browser which resulted in the shader.com box appearing. I had no time to study what happened as I was too busy making sure nobody knew I had a problem.
geposted Mon 02 Jul 18 @ 1:42 am
