The Pioneer CDJ 2000 NSX2 selector wheel for whatever reason will not work with newest build of Virtual DJ. All other functions normal. Anyone else have this problem? Any fixes besides downloading a previous build?
geposted Thu 02 Aug 18 @ 6:49 am
Could you try to modify the mapping, and change
ENC_BROWSE
from
var "dontbrowse" ? nothing : browser_scroll
to
browser_scroll
BACK
to
browser_folder
ENC_BROWSE_DWN
to
browser_enter
ENC_BROWSE
from
to
browser_scroll
BACK
to
browser_folder
ENC_BROWSE_DWN
to
browser_enter
geposted Thu 02 Aug 18 @ 11:18 am
Wish I saw this on Saturday, had the same problem at a gig in Italy.
I got by using the keyboard, but would have been great to have known this, rotary scroll wheel is so much easier to use.
geposted Wed 08 Aug 18 @ 9:15 am
The default mapper has been fixed in current early access release
geposted Wed 08 Aug 18 @ 9:22 am
Hmm that's strange as I'm on early access release already and updated only Thursday night?
Anyway its done now and got by fine on the night, so by the time I use a set of 2000NXS2 again it should be fixed as you said.
geposted Wed 08 Aug 18 @ 10:26 am
It was fixed in an additional controller update on monday.
You can check the controller build number in Options->Licenses.
At the bottom it will read build 1514.1440.
The second number is the controller build number, and the NXS2 issue was fixed in controller build 1440.
geposted Wed 08 Aug 18 @ 11:11 am
