Hey there. I would need a small help: before using VDJ i really like the Serato filter, which was different than VDJ, for example: when i put the filter all down in vdj, he cuts all the bass freqs, instead in Serato i still had bass freqs and it was more enjoyable. I don't know if i explained this well, but if you compare both are different, so how i can approximate the result of Serato to VDJ? Maybe if there's a config, or vdjscripts.
Thanks in advance!
Thanks in advance!
geposted Sat 04 Aug 18 @ 2:21 pm
No, all the bass is not cut with the VDJ filter. What's probably happening is that your speakers cannot reproduce the low bass when the VDJ filter is all the way down, so you hear nothing. I can assure you that there are still bass frequencies there. I can hear it on my small Creative computer speakers.
Another possibility is that the tracks you're playing don't have bass as far down as the VDJ filter goes, so again you would hear nothing.
geposted Sat 04 Aug 18 @ 2:38 pm
No the fact isn't this, because with the same track in Serato i can hear it, in VDJ not, so it's a filter thing
geposted Sat 04 Aug 18 @ 3:03 pm
So just turn the filter down a little less?
geposted Sat 04 Aug 18 @ 3:04 pm
Yes, this is what i've done everytime but i was thinking.. there's a way to set the filter like this?
geposted Sat 04 Aug 18 @ 3:05 pm
Yes, the fact is this! I don't think you understood what I tried to explain.
The VDJ filter does not cut all the bass.
The low pass frequency in VDJ is probably set lower than the one in Serato DJ - for example Serato DJ may cut off bass down to 40Hz but VDJ may cut bass down to 20Hz
Therefore, in Serato DJ you will hear bass from 40Hz downwards, but in VDJ you will only hear bass below 20Hz - so if your speakers cannot reproduce bass as low as 20Hz, you will not hear it, and you will think there is no bass.
geposted Sat 04 Aug 18 @ 3:44 pm
Ohhh Sorry, my bad! I probably didn't explain well:
I would have the same filter frequencies settings of Serato on VDJ
So it may be possible?
geposted Sat 04 Aug 18 @ 5:10 pm
Yes, in VDJ there are a lot of changes you can make to the filter
Here are some of them:
geposted Sat 04 Aug 18 @ 5:21 pm
