use a "filter folder" for the following:
initial conditions(assumptions):
you...
want a track with maximum 5 percent difference to the actual playing track
use rating for dynamic puposes
use finer rating for "between 3 and 4 stars" like this: "3<->4" in the comment section
want the next track to be 3 or 4 stars
store your house tracks in a folder structure like this: x.\Music\House\someOtherFolders\
the actual playing track is in 02B (camelot)
you want to test some more rules for mixing in key that you discovered online
try this:
BPMDiff<=5 and rating>=3 and rating<=4 and Comment doesn't contain "2<->3" and filepath starts with "X:\Music\House\" and key is E or key is B or key is F# or key is C# or key is G# or key is 11A or key is F or key is G or key is 02A
If you are interested in more filters like that my recommendation is to use Excel/Calc(LibreOffice) and learn how to edit the xml files to reach your goal with a little less work ;)
You'll have to invest in some work and time yourself to use this.
Please adopt it to your personal needs (maybe Mac folder structure; to fit you used tags and so on) :)
Have fun playing around with this.
short notes:
I _first_ used this with VDJ 7
as you can see I'm not a native english speaking person...so If you are confused about what i wrote than it's possible because of that ;)
Again: good luck and have fun :)
you...
try this:
short notes:
geposted Sun 05 Aug 18 @ 1:29 pm
'Accord already does this for you from your pads .
geposted Mon 06 Aug 18 @ 1:27 am
...another one by locodog :)
geposted Thu 09 Aug 18 @ 3:45 pm
One that I want to revisit, (I really like how it can change up the "echo chamber" with sets)
I can be a +/- 20% kinda guy, so the 3% limit is... well... not good enough
I can make this one more "dynamic", the script might get too heavy for a padpage, from previous adventurers with 1/4MB padpages, stuff gets hot,...
But a padpage plugin combo... There's room for improvement here.
geposted Thu 09 Aug 18 @ 6:02 pm
