Topic: OS2L... ANYONE USING IT
CURIOUS. Bought the compatible control hardware and have not started programming yet
geposted Tue 28 Aug 18 @ 5:02 pm
well this is a bad sign
:-D
I'm not sure which DMX products are compatible with it yet
There are a couple in beta an alpha, but I'm not sure which ones are ready for use
So I haven't looked into it yet
@burnyabad, what hardware did you buy?
USB DMX Interface Sunlite 2 Controller 1536CHs
Got it on ebay for 260 usd.
I´ve tried with Sunlite (latest beta) and VDJ 2018, but Sunlite does not react to VDJ. At first i only tried to get the bpm, but it does not work (didn´t tried other functions) So atm i stick with loop2be and midiclock. I use my old Behringer LC2412 as a controller for Sunlite, don´t really need the OS2L feature atm. Tought of trying to program an intro song with light support.
VDJ and Sunlite will connect each other with OS2L, as soon as the first OS2L action is triggered from VDJ. Thats why probably the BPM is not passed to Sunlite.
Take a look at this Wiki page for further info .. http://www.virtualdj.com/wiki/OS2L.html
Does not work for me. Sunlite does not react. Tried the pad with a button to trigger a scene. Don´t do anything?
Doesn't work for me either.. I get an "unable to open MIDI input error from my DDJ-1000 but I don't think this should be an issue?
Has anyone got this to work?
I have started using it. I am working through understanding all the options to trigger light changes but documentation is extremely sparse. I do have able to chance scenes as I need in one test song so far and it works awesome. I am using the latest version of Compushow. It used to be by Elation but is now owned and managed by American DJ. Be sure you have the correct version of Sunlight they say to use on the VDJ wiki.
https://www.virtualdj.com/wiki/OS2L.html
One trick I have already figured out on it for setting cue changes in a track. Play the song in VDJ and as the beat hits where you want a lighting scene change hit the next open music cue button to create a regular cue at that spot. Open the POI editor, find each of the new cues you just made, edit them for type=Action and set all the rest of the settings you want and close. This makes it much easier to get right one the beat instead of fumbling with the tiny wave form in the POI editor.
Btw for me, it only work if i install apple bounjour.
