Hi,
When I'm using Automix with any fade larger than 0s, it cuts songs abruptly if the audio in that song file ends exactly at the end.
For example, if the automix length is set to 2s, and the song has *no* silence at the end of it, the automix will cut the song 2 seconds before it ends.
Isn't there a way to tell automix to take into consideration the Automix Point if it's set to a later point in the file?
geposted Sat 01 Sep 18 @ 2:48 pm
Just tried, and it will fade the last 2 seconds of the song for me.
What automix settings did you use?
geposted Sat 01 Sep 18 @ 2:53 pm
