Hello, I bought an SB3.
I need the LE keycode to download a video plugin.
Is this possible knowing that the SB3 doesn't come pre-loaded with virtual DJ.
Thanks
Thanks
geposted Wed 17 Oct 18 @ 8:43 am
LE version only comes with the controller you purchase. You should have selected a controller that had a VDJ LE included.
https://www.virtualdj.com/products/virtualdj/price.html
geposted Wed 17 Oct 18 @ 2:16 pm
...but there's nothing stopping you from buying a Plus license for your SB3 (if you're only using it at home).
If it's not for home use then you'll need a full Pro Infinity license.
geposted Wed 17 Oct 18 @ 4:23 pm
