Good morning!
Can someone please help. I want to create a filter folder of all my 80s music I would also like it to show compatible tracks of the song that it is playing very similar to what Genius DJ does but I want it to show only the 80s music nothing else. I would like to do this with all my years. can this be done and if so can someone please tell me what to type in when creating a filter folder.
Many thanks
Many thanks
geposted Tue 06 Nov 18 @ 10:26 am
On my system under the Lists & Advice I have a folder called Filters. Inside that there is a filter called Decades. You can click on 1980-1989 for the 80s. Assuming all your tags are correct of course.
geposted Tue 06 Nov 18 @ 12:54 pm
Thank you for your reply. All I have in the Filters Folder is Duplicates All of my 80s music has the correct Date of when it was released. Can you tell me how I can create the same folder that you have, and will it also work and show compatible tracks?
geposted Tue 06 Nov 18 @ 1:52 pm
create a filter folder by marking Year=80 in the white box
and display all the music of the 80s
the liveFeedback will give you the song similar to the title that plays
just click on livefeedback will show the song
geposted Tue 06 Nov 18 @ 8:50 pm
