AutoBPMMatch is still set to "no" and when I push play, the BPM changes. Sync isn't highlighted, I've gone through my settings and I can't figure out what's causing it.
geposted Thu 22 Nov 18 @ 5:16 am
smartPlay ?
geposted Thu 22 Nov 18 @ 5:38 am
Adion wrote :
smartPlay ?
The club I work at has a Pioneer XDJ-RX2 and I found out the other DJ took it home and changed a bunch of settings on it and the controller was the problem. Now I get to make fun of him for using the beat matching.
Thanks for answering at least.
geposted Thu 22 Nov 18 @ 6:41 am
XDJ-RX2 has a "QUANTIZE" button.
Push that button to turn off quantize, and then everything will work as you expect
geposted Thu 22 Nov 18 @ 10:03 am
I was wrong, I used a basic Needs to Mixtrack 2 and it's doing the same thing. It's changing the BPM on play and not on load.
geposted Tue 27 Nov 18 @ 5:41 am
Adion wrote :
smartPlay ?
You might be right, it was set to "per decks".
geposted Tue 27 Nov 18 @ 5:48 am
Also, thank you for that knowledge.
geposted Tue 27 Nov 18 @ 5:49 am
Adion wrote :
smartPlay ?
Smart play does exactly what you describe, so there is a good chance that it was enabled on one of the decks (hence the per-deck setting)
geposted Tue 27 Nov 18 @ 6:17 am
