Djm-s9 works fine without timecodes active it’s only when i try to activate timecode that it does not recognize the time code signal . I was working fine prior to this build.
geposted Sat 24 Nov 18 @ 8:43 am
check to see if your audio config has changed
geposted Sat 24 Nov 18 @ 3:02 pm
I did but still no luck at all i never ran into this issue i updated S9 drivers and firmware as well and still same issue
geposted Sat 24 Nov 18 @ 4:42 pm
If you think it was caused by the update, go back to the previous build....
geposted Sat 24 Nov 18 @ 6:24 pm
Well i found out actually is my DJM s9 is really inconvenient at the time this happend, thank you guys
geposted Sun 25 Nov 18 @ 4:39 pm
