Hello, I'm using Virtual DJ8 Pro with a Pioneer DDJ-SB3.
I want it so I can bind a hot cue button on my SB3 to enable/disable the microphone as I am a presenter on an online radio station.
I've bound the mic to a hot cue and it enables the mic, but when I press it again, it does nothing and I can't disable the mic without manually clicking it off.
My Mic is a Samson C01U if that helps and it connects to the PC via USB. I'm on Windows.
Please help so I can turn off the microphone using my controller.
Thank you for reading.
geposted Tue 25 Dec 18 @ 8:30 pm
It would be helpful if you posted the script you used.
geposted Tue 25 Dec 18 @ 8:36 pm
Hello, thank you for your quick reply.
I only got VDJ today after using Mixxx for a while, and it seemed that I rebound the button a few times in settings and it now works somehow.
I hope you have a nice rest of your day and thank you again for replying :)
geposted Tue 25 Dec 18 @ 8:49 pm
