Forum: Addons
Topic: Traktor Kontrol S4 MK3 - Page: 1.75
Wahrscheinlich werde ich das , wollte nur nit das es in Vergessenheit gerät ;-)
buongiorno
volevo sapere fra quanto tempo arriverà l'aggiornamento per il controllore traktor s4 mk3
grazie
saluti paolo
locodog wrote :
If there's news, it will be announced here, and since there's no announcement there's no news.
Hallo,
klasse Mapping. DANKE!!!
Aber! Ich vermisse das schnelle vor/zurück spulen wenn ich am Turntable drehe.
Wäre schön wenn die Geschwindigkeit mit gedrückter SHIFT Taste höher wäre.
Gruß
Udo
A good better Mapping I have written .
But now I hope thats soon an Update where the Patters can Spin.
And the Displays works.
Than its a perfekt Tool.
Hello guys and dear virtual DJ developers.
I took the trouble to write to Native myself about the displays and platter.
The thing is, I wrote the developers of Native in German.
Therefore I will only be able to upload the emails including the answer in German.
But I hope that the Virtual DJ team can translate it so far.
My mail to Native:
Native's answer:
My answer to that:
Sorry that the screenshots are in German.
I hope the Virtual DJ team can translate that.
So the answer is from Native:
Software developers should integrate the functions in their software themselves.
I replied to them that this has already happened so far, but the displays and haptic wheels have to have a certain different code, and you can't find out.
Maybe it would be better if the Atomix team contacted Native and explained it to them.
Greetings Dani
My mail to Native:
Native's answer:
My answer to that:
Greetings Dani
Schreib ihnen nochmal, dass du nicht allein bist und wir alle die S4 MK3 für einen genialen Controller halten, aber halt VDJ auch und einen Controller kann man austauschen, das würden wir natürlich gern dann mit dem S4 MK4 machen, doch wenn das mit VDJ nichts wird......ich wechsel dann auf jeden fall wieder.
klausmogensen wrote :
According to the devs, that won't help (it was posted earlier):
"Actually no, he can't help. That guy modifies the way Traktor talks to the screens. He didn't create an app that talks directly to screens. Traktor still does the talking.
To make it "simple", this guy modified the "skin" of the screens. He didn't made a stand alone application that draws elements directly on the screens. And that's the issue here. If you can't draw on the screens by yourself, you can't "skin" them"
This Guy have modified the File that in the Native Instruments Program Folder :
C://Program Files/Native Instruments/Traktor Pro 3/Resources64
The Files in this Folder has the Name 'qml'.
These are the Files which Control the Display and Haptic Platters.
The Virtual DJ Team should take a Look in these Files.
I think this can help for make the Device and Mapping with Platters and Display ready.
Greatings Dani
I have downloaded also this Mods when needed. ;-)
Take there has been no movement on full support? Seen loads of updates for other controllers including s3 4 channel.
I would also very much like to know if there is any movement on S4 MK3 support. Please!
i hope a soon update for s4 mk3 with virtual dj.
keep waiting. Come On Virtual DJ you can do it
Hi! in new Virtual Dj release ( build 6167) there is:
- Improvements for controllers with motorized jog wheels
is for Kontrol S4 mk3 motorized jog-wheels to???
No change for S4 MK3.
The S4 mk3 is probably the best new controller for mid to high end mobile djs (at the price range) which is why I have decided to prioritise controller over software for the first time, I hope that virtual dj can map for this as it will be sad to leave after all this time but this is one of those controllers... Please keep trying, thank you.
I would love a virtual dj mapping for my traktor s4 mk3? Any updates please?
No, you will have to use the mapping you can get under extensions
Atomix can't get the screens and haptic feedback to work without help from Traktor - and they don't want to help
maybe someone can ask NI again? Unfortunately, my knowledge and English are not enough for that.
Sorry .
But unfortunately it doesn't help if Virtual DJ users ask there.
Native Intruments is simply stubborn and answers me as if I were stupid and had no idea. (See the emails I wrote to them a long time ago).
The only possibility that they finally cooperate would be the Atomix programmer who would write to them themselves and ask nicely.
Nothing else comes from them.
I am using the custom mapper. I am not able to hear anything in the headphone cue when the volume on the fader is down. when i turn the volume up i then hear the music which does me no good in a live dj setting. any thoughts on how to fix this issue? or could automix do a quick update??
Hi There
I'm trying to download the link but all it shows is "How to install...", it also doesn't appears in extensions in VDJ 2021.
I have a Pro license.
Any help?
Thanks
Tom
37%
