Just installed a new laptop and need tip if its possible to bring saved cue Points and loops from my old computer to the new one?
geposted Fri 01 Mar 19 @ 12:08 pm
Copy the entire database, you will get that info to your new laptop.
geposted Fri 01 Mar 19 @ 1:07 pm
Can you do this if you have a DB on a windows machine and are moving to VDJ on MAC?
geposted Fri 01 Mar 19 @ 1:34 pm
geposted Fri 01 Mar 19 @ 1:58 pm
does this work moving from windows to mac or just windows to windows?
geposted Fri 01 Mar 19 @ 2:17 pm
Done that, all playlists are on Place put no cue and saved loops.
geposted Fri 01 Mar 19 @ 2:59 pm
Your music folder needs to be in exactly the same place. (same username, folder location etc.)
If not, you can mass edit the database.xml file to match your new location.
geposted Fri 01 Mar 19 @ 3:12 pm
How do I mass edit?
geposted Fri 01 Mar 19 @ 3:17 pm
If you copied the music, all you need to do is first copy the database.xml file, then open VDJ, right-click your music folder and select recurse.
It should find the files in the database, even if they are moved, and thus preserve all cues and loops.
geposted Fri 01 Mar 19 @ 3:29 pm
Ahhh Daaaammmm..
Already moved 800gb and start using new laptop :(
Thanx anyway
geposted Fri 01 Mar 19 @ 3:35 pm
If you didn't add any cue points, just overwrite the database.xml with the one from your old computer and recurse then.
geposted Fri 01 Mar 19 @ 4:20 pm
