Strange but true im in need of a command , i am too burnt out to get it to do it, i dont know why its a issue . I need a hot cue push action to be: play the hot cue and stop when it gets to the next cue. cue 1 then stop at cue two . then when cue 2 is pressed it plays and stops at the end.. Thanks in advance,
geposted Tue 19 Mar 19 @ 11:41 pm
Globally for all songs? or just manually at songs you want to "edit" like that?
If latter, you can just change the 2nd cue point to action point instead, and set action to "stop" or "pause" in the POI editor.
(and play from first cue is easy, just the action hot_cue 1 )
https://virtualdj.com/manuals/virtualdj/editors/poieditor.html
geposted Wed 20 Mar 19 @ 12:12 am
Im willing to go through all of these videos , Imagine a game show question . first is the question and the second button is the answer all in the same mpg4.
just tried it, fantastic.. thank you. I had no idea. now to edit the videos to have a logo at that spot.. brilliant
geposted Wed 20 Mar 19 @ 8:24 pm
Something like this might work for you
repeat_start_instant 'rsiPlaySingleCue' ? on : off & hot_cue & repeat_start_instant 'rsiPlaySingleCue' 33ms & param_greater 'cue_countdown' 0.125 ? goto_cue +1 & pause & repeat_stop 'rsiPlaySingleCue' : nothing
geposted Wed 20 Mar 19 @ 8:36 pm
