Hi all
I'm trying to connect a Sound Garden Controller to Virtual DJ - Windows see the device as MIDI 8.
In the config I'm seeing the error message MIDI 8 (Failed to Connect), and none of the buttons on the controller work.
I can't find any updated drivers anywhere - can anyone help please?
Many thanks
John M
Many thanks
John M
geposted Sun 24 Mar 19 @ 10:08 pm
"Home Plus" licensed version of VDJ is needed. Home edition not enough even for a simple MIDI controller
https://www.virtualdj.com/products/virtualdj/price.html
geposted Sun 24 Mar 19 @ 10:26 pm
Did you check the list of supported controllers? Is it listed?
If it's not natively supported then it won't be plug & play. You'll have to map it yourself - and of course buy a license so you can use the controller for more than ten minutes.
geposted Sun 24 Mar 19 @ 10:34 pm
Ah Right - thanks all - more research needed
geposted Sun 24 Mar 19 @ 10:47 pm
