Hi,
It now seems to be impossible to reorder folders (Virtual or Favorite folders) even when lockFolderOrder is switched off!
When you close VDJ and reopen the last and previous order changes are lost and it reverts to previous folder order.
(Win10 16gb Ram i73630QM)
p.s. on another laptop it seems to work correctly
p.s. 2 can we get a button (lock icon) or at least make the lockFolderOrder mappable to a Custom button
geposted Tue 26 Mar 19 @ 6:04 pm
2
setting "lockFolderOrder" On ? on & setting "lockFolderOrder" Off : off & setting "lockFolderOrder" On
geposted Wed 27 Mar 19 @ 6:33 am
Or even more easy
geposted Wed 27 Mar 19 @ 6:46 am
ok Great thanks! =)
and the bug?
again: you can reorder folders but when restarting VDJ everything is back to before. Doesn't seem right.
and the bug?
geposted Wed 27 Mar 19 @ 1:07 pm
Seems to work fine here, so perhaps check write permissions of Documents\VirtualDJ folder, and Folders subfolder. (or the 'order' file in the specific folders that you try to rearrange)
geposted Wed 27 Mar 19 @ 1:10 pm
That resolved the issue! Thanks a lot
geposted Wed 27 Mar 19 @ 1:18 pm
