Topic: impossible de me connecter à internet avec le logiciel VDJ
bonjour, je viens de m'abonner à la version Pro de VDJ
Problème impossible de me connecter à internet meme avec le pare feu et l'antivirus désactivé
aidez moi svp
geposted Fri 29 Mar 19 @ 12:36 am
It could be your hosts file
go to C/Windows/system32\drivers\etc\hosts and open it with notepad and search for "127.0.0.1 live.virtualdj.com " delete it and save the file to the desktop since it won't let you save it directly to that folder and then delete the host file and replace it with the saved file and it should work.
