Topic: Phase don't work [solved] - Page: 3
geposted Wed 17 Apr 19 @ 4:52 pm
jagrutdPRO InfinityMember since 2015
I am trying to use ni traktor z2 with Phase DJ but it doesnt detect the signal from phase. Has anyone made it work with Virtual DJ?
geposted Fri 10 May 19 @ 1:55 am
Great post #70, really informative.
You need vdj BUILD 4918
Set up your z2 for timecode
Put each of the z2 channels in Line pc mode
Make buttons #29 orange to activate timecode processing for the corresponding deck.
Then reread this thread for picking noisemap and timecode settings.
If you're still stuck post details
geposted Fri 10 May 19 @ 2:28 am
alixrippon971 wrote :
what about your audio config, i am at work so my phase and my mixer are not plugged. Send us a picture and i will compare.
Can u help me
geposted Sun 04 Dec 22 @ 9:46 pm
HAHA! I figured it out! I was having all the same EXACT issues! So frustrating especially with all this crazy money we spend on the best gear, phase, s9, turntables, VDJ!
X OUT THE ROUTING UNTIL YOUR LEFT WITH NOTHING IF CAN THEN HIT THE S9 ROUTING CONFIGURATION BUTTON AGAIN
Hope that helps!
geposted Sat 30 Sep 23 @ 8:12 pm
