Hi Vdj team! I have spotted one thing what needs to be fixed it's not big thing but would be nice to work properly! When I press reverb and after I press loop out while I'm mixing to another song the one I have applied two effects on the end looping out it gets like big tick, klick of the audio would bi nice to fix that , it's not big problem but it gives you sound what you don't wanna be there in the mix.
geposted Thu 18 Apr 19 @ 9:44 am
tested here, to me it looks like it is just loop out with stop on it's own, with hp or lp mode you don't hear it, but you do with buffer based plugins. [reverb, echo]
It's like [when using loop out with stop] it could do with keeping whatever treatment it does to the sound on for 1/4 to 1/2 a second after plugin stops
geposted Thu 18 Apr 19 @ 10:10 am
Will be fixed, by making sure loop out is always processed first (which has the added benefit that echo or reverb trail can continue after the track has stopped)
geposted Thu 18 Apr 19 @ 10:17 am
Adion thanks very much!
geposted Thu 18 Apr 19 @ 5:53 pm
Thanks ,Adion ! for this little issue fixing I have tested the latest version all works perfectly and how it should be,thanks to all Vdj team for the best customer service in the world. You guys just keep that way to listen what other Dj's. need and Vdj is the best and forever will be . What a service I'm impressed with the service you provided.
geposted Tue 14 May 19 @ 12:28 am
