Just repeating this from other thread since it is such an important change.
These have been useful and thank you.
Adion has mentioned the addition of another new flag to control the FPS of a plugin running on a deck which would then make decks much more useful. Without such a flag, the plugin is at the mercy of what ever the FPS of the current video might be.
To exaggerate this problem try this video. It has only a frame with a duration of little over 2 seconds. Any plugin run on the same deck as the video will appear to be frozen.
http://www.tellyvisuals.com/633.zip
Adion wrote :
Still have to update the sdk downloads, but there are 2 new flags that video plugins can use in the current early access release:
#define VDJFLAG_VIDEO_OUTPUTRESOLUTION 0x400000
#define VDJFLAG_VIDEO_OUTPUTASPECTRATIO 0x800000
geposted Sat 20 Apr 19 @ 1:01 pm
