This is the scenario; you're in a 8 loop, the loop_in is on the 8th beat, you are on the 14th beat, you turn slip_mode on and call a hotcue, you hold the hotcue for 4 beats and release.
Where should the playhead return to? Beat 18 (this is what happens) or Beat 10 (obeying the loop, what I think should happen)
geposted Tue 30 Apr 19 @ 9:54 pm
If you have slip mode enabled, the track picks up where it would have if you hadn't looped. if you want it to obey the loop, turn slip mode off.
geposted Thu 02 May 19 @ 12:02 am
slip mode is turned on after the loop has engaged, and if slipmode is off how will it return after releasing the hotcue?
geposted Thu 02 May 19 @ 9:18 am
