Topic: Enable/disable Freestyler8
anok4u2PRO InfinityMember since 2011
Hi , disabling the freestyler8-button in the masterpanel is not possible (pushing the button), when the effect in tself is set to "enable", is this normal?
geposted Thu 23 May 19 @ 4:44 pm
Since the effect is on folder "Auto-Start" this is normal
geposted Fri 24 May 19 @ 6:39 am
