Hi guys,
I was trying to record something only to realise when I save the recording it records only the mic input.
Bear in mind that I was using only the laptop, so it's the internal mic that got recorded. The mix was not recorded at all!
In the sound settings, my master output isset to the internal sound card and the reording input is also set to the internal sound card.
I went as far as to disable the mic in wondows settings and somehow that did NOT make a difference.
I've included a pic below of the soun settings. What am I doing wrong?
geposted Fri 24 May 19 @ 11:57 pm
Remove the record input, you don't need it if you only have a master output.
geposted Sat 25 May 19 @ 1:40 am
