When i put in the name of the filter folder and press OK nothing happens, can´t see the filer folder anywhere, works fine to create av red virtual folder
geposted Fri 31 May 19 @ 11:18 pm
geposted Fri 31 May 19 @ 11:43 pm
Yes, you are right but it's already reported
geposted Fri 31 May 19 @ 11:52 pm
Ok thanks, i must read the forum better .. :-)
geposted Sat 01 Jun 19 @ 7:05 am
