Hi Guys
I have just downloaded the latest version of Virtual DJ, I am trying to play around using the Automix function. But for some reason Virtual DJ App is not allowing me to change the Fade length its set on 4 seconds, is it not possible to increase the time up to 30 seconds?
geposted Sat 01 Jun 19 @ 12:19 pm
From the Automix Type sub-menu, you need to select one of the "Fade - " types. If one of them is selected then the Automix Length sub-menu will be available too.
If the desired value is not listed, you can set it from VDJ Settings->OPTIONS tab ->fadeLength setting
The setting (Fade Length value) will have no effect is the "Smart" or the "None" Automix types is selected.
geposted Sun 02 Jun 19 @ 1:15 pm
