HELP!! I have just installed VDJ8. Weeks of work tagging hundreds of tracks has been flushed away. Does anyone know how I can get my tags back. I have backups of the VDJ files from the previous version prior to installing the latest version.
geposted Thu 13 Jun 19 @ 2:41 pm
Be sure there is no old VDJ instance running in background taking exclusive use of the database, sometimes the database seems to have lost everything simply not being accessible.
If your tags were / were not writted into tracks, it looks like you created a new database with new install : you may try to exit from VDJ and restore your saved database.xml
If tags are written in your tracks and previous didn't work, you may simply batch reload tags ... with some missing stuffs
Some usable security "<VDJFOLDER>/backup/2019-MM-DD hh-mm Database Backup.zip" backup database might exist in your backup from the previous version
if files are on another partition but the one VDJ stay it must not append unless database is unreadable/not accessible
maybe someone can have more ideas
geposted Thu 13 Jun 19 @ 3:06 pm
