Did you seen my screenshot?
Do you before my Laptops???
Go away, the problem is solved
geposted Wed 19 Jun 19 @ 4:29 pm
Yes. Did you see djdad's screenshot?
WASAPI is built into Windows. Every Windows computer since Vista (2006) has WASAPI, including yours.
geposted Wed 19 Jun 19 @ 4:34 pm
mobilbude wrote :
So we know only the old Denon Controllers are no longer supported.
This is not accurate. ALL Denon Controllers are supported. It's just the ASIO driver of some that is blocked and WASAPI used instead.
There is really no issue with using WASAPI even for the ones that their ASIO driver is not blocked and can be used properly.
Exactly. WASAPI is Microsoft's own version of an ASIO driver (low latency).
https://newsandviews.dataton.com/what-is-wasapi
geposted Wed 19 Jun 19 @ 4:40 pm
Your screenshot seems to be taken with the MC4000 not connected (since the ASIO driver failed to connect according to the screenshot)
geposted Wed 19 Jun 19 @ 4:52 pm
AGAIN it is connected!!!
I listen to the music.
geposted Wed 19 Jun 19 @ 4:53 pm
Into the Windows Sound Config was the Denon Line deaktivated.
That the reason, why i don't saw WASAPI.
Sorry
Sorry
geposted Wed 19 Jun 19 @ 4:59 pm
mobilbude wrote :
it is connected!!!
Then why is your config not showing the Denon MC4000 like this picture?
mobilbude wrote :
it is connected!!!
Because... Into the Windows Sound Config was the Denon Line deaktivated.
geposted Wed 19 Jun 19 @ 5:05 pm
Thank you for this block. The Denon ASIO drivers have been a pain in the neck for most of us, since the MC6000 was released. This is still my main controller for mobile gigs.
geposted Wed 19 Jun 19 @ 6:33 pm
Team!
Can you unlock the denon asio driver for HC4500 now it shut! down the software.
even in wasapi mode not working for me. (build 5045)
l'm rolling back on (build 4787) everything work fine! here.
Never have this issue since 2009 My HC4500 was work perfect with denon asio driver till you guys block it in build 5045.
Thank you..
Thank you..
geposted Fri 21 Jun 19 @ 3:25 pm
What's your problem with wasapi exactly?
geposted Fri 21 Jun 19 @ 3:51 pm
ln wasapi mode no sound coming out true the channel. (build 5045)
its weird if I choose denon asio driver. the software close. immediately
geposted Fri 21 Jun 19 @ 4:11 pm
What does the audio setup look like you used for WASAPI?
What's shown at the last column in grey?
geposted Fri 21 Jun 19 @ 8:46 pm
Ok here's my sound set up in wasapi mode, so no sound coming out.
geposted Sat 22 Jun 19 @ 3:09 am
Ok no way to work in wasapi mode in (build 5045)
the only solutions for now, it's using different sound card.
Now i'm use my Rane MP4 sound card instead denon asio driver.
so please! fix this issue as soon is posible.
thank you..
Ruben.
thank you..
Ruben.
geposted Sat 22 Jun 19 @ 4:01 am
I see your audio is set to 48k. Somewhere on here is a post from a user saying that the audio has to be set to 44k1.
geposted Sat 22 Jun 19 @ 6:27 am
It's also saying 2o, so only 2 outputs instead of 4.
So it's likely that the sound settings in windows are incorrect. They should be set to 4 speakers, and you can indeed try to switch to 44kHz as well.
geposted Sat 22 Jun 19 @ 9:05 am
With my MC6000mk2, I also have big trouble using wasapi, because I get no sound in headphones when trying to listen to "cue" sound, only master sound gets through.
Can someone please give me a link to the last version where asio drivers are supported?
geposted Sat 22 Jun 19 @ 12:42 pm
How does the speaker configuration in windows look like?
geposted Sat 22 Jun 19 @ 12:44 pm
