I've just about hit 1/3 million addon downloads [I'm as surprised as you are] So I best make some thing new to get to 1/2 million.
A couple of weeks back I had an idea I should have had ages ago [given my loopy jungle, breakcore tastes], I started it 2-3 days ago and am getting close to needing windows beta testers.
[mac users I have a contact who can port it to mac but it's his choice if he does or not]
The idea;
Multi-stage looper. [very much like loopOut plugin, but] 4 stages, 8 save slots. Loops 1/8th to 8 beats [including lesser used sizes like 1/3rd, 1/5th & 3/2] and max 32 repeats per stage. You can also make a stage not loop, so it will just play for the duration of that stage then it will move to the next stage.
As always, post here or pm me if you'd like to test.
The idea;
geposted Fri 19 Jul 19 @ 11:24 am
Well the "not looping" function gave me a bit of a headache, [actually it still is] but as you see with saved sequence 1 [first 2 runs] it works, I also added a continue button [>>] , with slip on and a "no loop stage" in the sequence it will progress thru a track and keep on doing it's thing. [like it does 2nd run of first sequence]
*fixed bad link, I iz idut*
geposted Sun 21 Jul 19 @ 2:46 pm
