Yea so all my audio fx have been removed, including the stock ones how do I get them back?
geposted Fri 26 Jul 19 @ 3:01 pm
Do you mean samples? Try the recycle bin.
geposted Fri 26 Jul 19 @ 3:13 pm
Simply restore them from one of the regular backups you take of your important stuff.
You do take backups?
Alternatively, download them again from here (if they're VDJ effects). You can do this from within VDJ now.
Another mention here too for the recycle bin. It's been a part of Windows since 1995.
geposted Fri 26 Jul 19 @ 3:54 pm
