I get some problems using "get_browsed_scrollsize"
it returns the correct value most of the time but count start with 4
when browsing folders with 0 1 2 or 3 files it returns 0
geposted Fri 02 Aug 19 @ 3:38 am
get_browsed_scrollsize was added to help mapping of Numark NV/NVII screens and the values were set accordingly. In which case you need to use this action ?
geposted Fri 02 Aug 19 @ 10:39 am
Trying to simulate the list of tracks in a custom browser, I found it usefull to use it in a way to make a pannels with track info visible when filled.
visibility="get_browsed_scrollsize & param_greater 1"
instead of testing against filepath as i actually do for the 8 first tracks
visibility="get_browsed_song +0 filepath & param_equal '' ? false : true"
geposted Fri 02 Aug 19 @ 12:16 pm
Use file_count instead, but still none of these actions will tell you how many tracks fit in your browser window, since this depends on the font size, unless your custom browser is displaying tracks on a constant layout
geposted Fri 02 Aug 19 @ 1:36 pm
Thanks, i didn't think to file_count , maybe it was too simple ^^
Yes for now it's a constant layout 3x14 grid
geposted Fri 02 Aug 19 @ 2:43 pm
