Topic: VDJScript - nesting condition operators
I am trying to figure out how VDJscript works, for one, with regard to nesting conditional operators.
It doesn't look like there are parenthesis in the language to make it clearer, so I'm trying to figure out the order of operations. I would like to know how nested conditional operators work. To copy one example from https://virtualdj.com/wiki/VDJScript%20Examples%20Database.html:
var 'double' ? set 'double' 0 & repeat_stop 'myrep' & device_side 'left' ? deck left clone_deck right : deck right clone_deck left : set 'double' 1 & repeat_start 'myrep' 400ms 1 & load & set 'double' 0
Is that to be interpreted as (parenthesis added by me):
var 'double' ? ( set 'double' 0 & repeat_stop 'myrep' & device_side 'left' ? deck left clone_deck right : deck right clone_deck left ) : set 'double' 1 & repeat_start 'myrep' 400ms 1 & load & set 'double' 0
Also, is the value of the conditional operator the value of the side that ends up being executed?
Thanks,
Doug
geposted Sun 25 Aug 19 @ 8:37 am
