HOLA
Is it possible to make a visual of the maximum frequency spectrum that have the mp3 being played?
Es Posible Realizar una visual de El espectro de frecuencia maximo que tienen el mp3 que se esta reproduciendo ?
as well as volume meters, but maximum frequencies
It would be with the objective of detecting the cut of frequencies produced by the compression of mp3 and to detect mp3s with bitrates fakes.
asi como los medidores de volumen, pero de frecuencias maxima
Seria con el objetivo de detectar el corte de frecuencias producidas por la compresion de mp3 y detectar mp3s con bitrates fakes.
Gracias por su tiempo.
geposted Mon 16 Sep 19 @ 1:44 am
But why would you have MP3s with fake bitrates? Are you downloading them illegally?
Besides, if you can't hear that they sound bad, does it matter that they have less HF?
There isn't a fixed amount of "correct" HF on every track anyway. It depends on the age of the track, how it was mastered, the instruments and equipment they used......
These things are more commonly found in DAW software, for production. This kind of tool should not be necessary for DJs because they play tracks that have already been mastered.
It looks like you already have a VST plugin to do this, so there's no need to have anything built in to VDJ.
geposted Mon 16 Sep 19 @ 7:54 am
