Is anyone aware of a vdjscript command which will add a song to whichever playlist is currently set in the sideview? Playlist_add only adds it to automix, but I'd like to be able to add songs to my own playlists which are currently shown in the sideview
geposted Tue 17 Sep 19 @ 6:50 pm
have you tried -> sidelist_add
geposted Tue 17 Sep 19 @ 7:27 pm
something like that:
param_equal 'sidelist' `sideview_title` ? sidelist_add : param_equal 'automix' `sideview_title` ? playlist_add : param_equal 'karaoke' `sideview_title` ? karaoke_add : nothing
geposted Tue 17 Sep 19 @ 10:08 pm
Thanks for your replies,
Sidelist_add works only for the sidelist,
I would like to add to whichever custom playlist or folder I currently have loaded in the sideview (i.e. not sidelist/automix/karaoke etc)
geposted Thu 19 Sep 19 @ 8:17 pm
Try this..
sideview 'automix' ? playlist_add : sidelist_add
It'll add it to whichever one you have on screen.
geposted Fri 20 Sep 19 @ 5:12 pm
A more improved script..
Will add to Automix, Karaoke, Sidelist (which ever is visible), but not if Sampler or other Shortcuts (Cloned) Folders
sideview 'karaoke' ? karaoke_add : sideview 'automix' ? playlist_add : sideview 'sidelist' ? sidelist_add : nothing
geposted Fri 20 Sep 19 @ 5:16 pm
What I mean is, I have my own playlist (for example Friday Warmup.m3u) that I load into the sideview?
Using the add shortcut button (little arrow bottom right)
I'd then like to add to that playlist which has been shortcutted to the sideview using a vdjscript
geposted Sat 21 Sep 19 @ 9:21 pm
I have tried and can see how it doesnt work.
I dont know how your workflow is, but it would be easy to load the wanted playlists from the browser "into sidelist" or "into automix" and just add the songs to the loaded list and save it with the new songs?
And use a script on buttons for loading the playlists from the browser and save the playlists.
Can someone help with script for "save loaded playlist" and "load marked playlist from browser" ?
geposted Sun 22 Sep 19 @ 7:28 am
Did you ever get this working? Trying to map a button to display a shortcut I created in the sideview.
geposted Fri 12 Jun 20 @ 2:18 pm
Nah, I just drag them into the playlist with the mouse. Couldn't think of a way round it :-(
geposted Sat 13 Jun 20 @ 10:16 pm
playlists automatically register in "list & Advice\playlists" as default and karaoke and sidelist
to load you may map button for
karaoke_load
playlist_load
sidelist_load
karaoke_load
playlist_load
sidelist_load
geposted Sat 13 Jun 20 @ 10:40 pm
@grenno, from what you've said in this thread, you're not using sidelist, playlist, karaoke or automix - so all those existing scripts to _load or _add won't work.
You have a shortcut or clone in that window, and as djdad already said, the script won't work for that view.
Looking at the VDJScript page, verbs exist for adding tracks to the other views, but not to 'clone' which is just a shortcut to another location.
geposted Sun 14 Jun 20 @ 8:26 am
