Wondering if anyone can help me figure this out... all the songs from my Serato crates list are showing up as duplicates.... if I recurse the parent folder and a file is sorted in 2 different sub folders (eg: "Hip Hop" and "New Songs") it shows up multiplied by 4, even though there is only the one file on my hard drive. I can't seem to figure out how to fix it. Thanks for your help!
*Screenshot attached*
geposted Thu 19 Sep 19 @ 7:15 am
Try to set the showM3UAsFolders setting to No (from VDJ Settings->OPTIONS)
geposted Thu 19 Sep 19 @ 3:06 pm
thanks, I have already done this. Same issue.
geposted Fri 20 Sep 19 @ 5:31 am
still no solution to this... can anyone help!?
geposted Fri 04 Oct 19 @ 2:47 am
If all parents (including Crates folder) are not recursed and showM3UAsFolders setting is set to No , then VirtualDJ will just read the crate as is.
Any chance your Serato crates have duplicated tracks ? (you need to check in Serato for this)
Cant think of any other solution i am afraid.
geposted Fri 04 Oct 19 @ 8:46 am
I'm also having this problem. Did you ever find a solution?
geposted Sun 06 Sep 20 @ 9:52 pm
