Hello!
If I turn this knob on "master" I don't hear the master output in my headphones also if the cue button of master level is pressed. What can I do?
Thanks a lot.
Thanks a lot.
geposted Sun 29 Sep 19 @ 5:31 pm
I'm talking about a Pioneer DDJ-400...
geposted Sun 29 Sep 19 @ 5:45 pm
And I'm using it setted on Built-in Output for Master and DDJ-400 Audio Out for Headphones.
geposted Sun 29 Sep 19 @ 6:58 pm
Well of course you won't hear the master signal on the DDJ-400 if you're sending it somewhere else.
geposted Sun 29 Sep 19 @ 7:16 pm
I think he's trying to hear what is output on the master in his headphones as well.
On my DDJ-RX, I enable the master CUE/PFL button and turn the headphone mix knob to master. You have to have the master outputting as well as bring the headphone volume up.
Do you have speakers hooked up to the master out to verify you are actually putting out sound?
Do the other channel CUE's output into the headphones when you are headphone mixed to CUE?
geposted Sun 29 Sep 19 @ 7:57 pm
The Headphones Level and Mixing are hardware operations on the DDJ-400, meaning that you need to use the default Audio setup (with both Master & Headphones assigned to DDJ-400 sound card).
If Master is routed to a different sound card, the hardware CUE/MASTER mixing will not work as expected.
A workaround is to create a custom mapping for your home practice and edit the action of the ONINIT key from:
to...
In this case the MASTER CUE/PFL button will not make any difference (its not mapped anyways)
fake_master on & fake_hp on & fake_hpmix on
to...
fake_master off & fake_hp off & fake_hpmix off(same as the ONEXIT key)
geposted Sun 29 Sep 19 @ 8:16 pm
Right!
I hear the master output from the Mac (just for practice)
Yes, and when I used DDJ-SB2 the same set up worked.
Right!
geposted Sun 29 Sep 19 @ 8:20 pm
:-( Better with the DDJ-SB2...
geposted Sun 29 Sep 19 @ 8:24 pm
Running VDJ8 on a Pioneer DDJ-SX3 controller. I'm not getting any MASTER audio feed on my headphones (CUE only). Anyone know how to fix this?
Andy
Andy
geposted Sat 16 Nov 19 @ 6:31 pm
