Topic: Annoying Pop Up "Current location"
Well after i installed 2020 version it started to pop up a message that says "Virtual dj would like to use your current location." It has 2 options, "don't allow" and "ok". it pops up every 1 min no matter what u gonna choose and its very annoying... Anybody knows how i can stop it??? Thanks
geposted Mon 30 Sep 19 @ 7:05 pm
Probably you are using ask the dj?
Check in your mac preferences-> Security & Privacy -> Privacy if VirtualDJ is listed (and granted access) in Location Services.
geposted Mon 30 Sep 19 @ 9:54 pm
Well yes i m gonna use ask the dj from now on... I checked in privacy and and vdj is checked... still poping up with no reason...
geposted Tue 01 Oct 19 @ 7:47 pm
