There is no longer an option in layouts to chose how many deck you want?
geposted Wed 02 Oct 19 @ 1:10 pm
go to the pro skin, 4 decks selection is there [it will remember this if you then switch to performance]
geposted Wed 02 Oct 19 @ 2:21 pm
Just bear in mind that you can only switch to 4 decks via the Pro view, even though Performance view can have 4 decks.
If you want 4 full size decks, then selecting vertical waveforms in Performance view is the only way.
geposted Wed 02 Oct 19 @ 4:47 pm
