Hello, i started to use VDj20 and the same problem comes like in previouse versions. I use Pioneer DDJ-SB2 and Brakestart effect works perfectly on deck 1 but on deck 2 it doesnt work, just stops the song and if i press it again the song starts again, like a play/pause button. What should i do?
geposted Wed 02 Oct 19 @ 2:22 pm
Check the fx parameters for deck 2 maybe you have it set low
geposted Wed 02 Oct 19 @ 2:26 pm
