On my desktop PC, I have it, like this.
edit: also noticed it is not on Deck 2 at all. How do I get it?
edit 2: just figured it out, clicked this double down arrows above the circled area. they are not on my laptop so that doesn't solve that issue.
On my laptop in the same area. it just has a dropdown list with musical keys, it doesn't seem to work the same. How do I get the lock on my laptop?
geposted Mon 14 Oct 19 @ 1:32 am
Use masterTempo
geposted Mon 14 Oct 19 @ 1:58 am
How do I do it exactly? I tried the checkboxes in options but it doesn't seem to give me this.
geposted Mon 14 Oct 19 @ 2:34 am
options masterTempo yes
geposted Mon 14 Oct 19 @ 3:05 am
That does the opposite of what I want, I should clarify though, what I want this for is to able raise/lower the song pitch, and then lock the pitch, then alter the tempo, that's what I've been able to do with this lock icon.
geposted Mon 14 Oct 19 @ 3:28 am
The dropdown and the +/- are both key change by semi-tones (which also changes the pitch, yes), so they should be the same
geposted Mon 14 Oct 19 @ 10:24 am
