Topic: VDJ track bar/graph touch issue
hello all.
I'm having an issue with my "touchbar" at the top of the software. The big graph with both tracks on that you can touch and move around...
90% of the time, when I load a new track it will be that one my 'hand' grabs on that big top bar, but sometimes it will grab the track playing!! Surely shouldn't be happening, and I can't see that it's a setting... help!!
anyone had/has this issue and has resolved it?
Many thanks
geposted Wed 16 Oct 19 @ 6:42 pm
"Hand" grabs the active deck.
So if you switch active deck it will switch which deck it works on.
Settings to check:
autoPpf -> Set it to "On Load"
pflOnSelect -> Set it to "yes"
Finally, even with those settings enabled if you use "TAB" button on your keyboard, VirtualDJ will switch the active deck.
So keep that in mind!
PS: When a deck is active it's waveform becomes more bright / is drawn on top. Therefore it's easy to understand on what deck the "hand" is going to act upon.
geposted Wed 16 Oct 19 @ 8:32 pm
Also, some rhythmwave views allow you to grab either wave at any time.
geposted Wed 16 Oct 19 @ 8:52 pm
Thank you phantomdeejay. I can't find 'autoPpf' anywhere
- can anyone help? I've looked down the settings list 4 times...
Tab works - thank you.
geposted Fri 18 Oct 19 @ 6:11 pm
Try autoHeadphones...
geposted Fri 18 Oct 19 @ 6:22 pm
