In the Tag Editor, we have a button to load tag from filename which is useful, but some music providers are putting the artist and title the wrong way round.
Could we have a quick button to sway the artist and Title fields around please?
I don't wanna have to just use a 3rd party editor or have to keep copy pasting between multiple fields just to swap these please.
AND while were on the subject of tag editor, some files come with track number at start of file name, could something be added to move the number to the correct field instead of keeping artist like > 01 David Guetta, etc
geposted Thu 17 Oct 19 @ 3:11 pm
For your 1st problem..inside the tag editor..you can use a little trick i have come across..using this example
A track you downloaded has avicii as title and levels as the artist(wrong side).in the editor...use the rename track at the bottom..inverted(putting the artist first instead) naming the track correctly
Then just click get tags from filename on top.
geposted Fri 18 Oct 19 @ 3:13 am
