Hello
Using NS6II and Virtual DJ and a couple questions:
1. I have a microphone plugged in to my NS6II mic 1 input and I cannot hear it in my headphones (testing at home with no PA hooked up). I have added MIC as an Input in the Sound settings but I am not sure what to select (see photo)
2. My BPM fader seems delayed on my controller. I have to wiggle it up and down to get it to respond. Is there a latency setting that can be changed?
Thanks everyone
Thanks everyone
geposted Fri 25 Oct 19 @ 12:49 am
I would think you need to select line 1/2 for master, and line 3/4 for headphones.
I don't think the NS6ii tea even presenting a line in there. Those all look like line outs to me.
geposted Fri 25 Oct 19 @ 2:00 am
So the photo here is how it's supposed to be configured but if you notice it switches the Audio portion to Computer Audio. Whilst selected on NUMARK NS6II it will not let me mirror these settings. Ideas?
geposted Fri 25 Oct 19 @ 2:07 am
Have you installed the ASIO drivers?
geposted Fri 25 Oct 19 @ 3:06 pm
For qn2, If I am right, I had this issue with both pitch fader and frequency gains on SZ2. Try adjusting these and see if it does help, under settings:
controllerTakeoverMode:
controllerTakeoverMode Pitch:
geposted Sat 26 Oct 19 @ 1:50 am
It appears that the NS6II is having a different ASIO name in 64bit, that is why the default audio configuration was not giving the ASIO setup. We fixed that for next update.
The microphone Input is not part of the USB Audio interface. Its signal is going straight through the Master Output, so cant be added to the Audio setup of VDJ. If you can't hear Mic in your headphones, then this is something the firmware of the unit needs to handle. Nothing VDJ can do about it. What you could do probably - but still unsure if it will work - is to set the HEADPHONES MIXING knob (front panel) to Mix (hoping that the Headphone Channel of the NS6II is "hybrid" and includes the Mic input when receiving the signal from Master/Mix).
The 2 Inputs can be used as Line Ins or DVS inputs as per manual .. http://www.virtualdj.com/manuals/hardware/numark/ns6ii/advanced.html
geposted Sat 26 Oct 19 @ 2:29 am
